Hi, my area is SY23. I'm using ID since one year and a half, never had the best signal but it was acceptable. Since 2 months signals get really poor, so often no connection at all.
As an example I can send and receive WhatsApp messages but I can't send or receive photos, I can't make a video call. I can't watch Instagram stories, you tube videos. I can't listen Spotify. I need to use card reader for my work over my mobile connection, most of the time I have problems. I'm not even talking about watching stream channels.
I know ID is of the cheapest options but if that means such poor signal it doesn't worth it at all.
Even though it shows full connection, can't able to open a simple google page. (photo attached)
Everytime I swith off and on the mobile connection or the device but that doesn't work. This is really getting annoying.
Any advice is appreciated.
