where to report a network fault
  • 9 June 2023
  • 175 views
Hi who or where can I report a network fault to ?
I’m working from home with a broken leg and I cant get internet.
Phones working fine as tried a different sim.
I can get texts and voice but no Data.
Many thanks
DE74LN postcode Ilkeston Derbyshire
OK so tried my sim in a different phone and it didnt work, so its the Sim or the Network, as no one has touched my sim I’m betting its network.  Can anyone assist me please ?  Thanks
If your iD SIM doesn’t work in two different devices @Lee Wheeler, sounds like you’ll need a replacement SIM card.
Hi @Lee Wheeler
I’m sorry to hear you’ve had issues in your area with signal, if you’re having the same issue across multiple devices it does indeed point towards the signal or SIM card being the cause of the issue.
How long have you had this issue? I don’t see any outages reported in the area.
Does data work in other areas?
