Why roaming stopped working in fuerteventura?
  • 14 July 2023
  • 118 views
Hi @Remus1307,
We did have some issues with roaming which have now been fixed.
Are you still having issues with roaming?
You’ll need ensure that roaming is enabled on the app and your handset.
Please also check that you are connected to either Yoigo or Movistar, if not you can do this manually via your network settings.
