why doesnt wifi calling work? ive just joined id mobile and the signal where i live is awful, wifo calling is active in my settings samsung s22 plus, but the wuality is awful, nobosy can here me, however ive never had this issue before with previous pro idersĀ
Hey
Did you use the Galaxy S22 with your previous providers?
Perhaps you could setup a VLAN on your home Wi-Fi network, forĀ any devices needing to use iD WiFi Calling, and set a high quality of service for this VLAN.
Ā
Hey
If your device is set to Airplane mode, then you enabled WiFi and connect to it as well as turn on WiFi Calling, are you able to make calls?
Ā
Ā
Try changing the WiFi calling preference from mobile to WiFi. This helped me with a different network. Also worth noting that S22 series are not currently on the supported list as perĀ this thread https://community.idmobile.co.uk/device-phone-support-26/samsung-s22-wifi-calling-55774
Ā
