I received a new sim when switched networks. I did the puk and kept my old number. But people tell me it's the new number that shows when I text. The phone and account show me my old number how is this . Thanks
Best answer by Mohammed
View originalI received a new sim when switched networks. I did the puk and kept my old number. But people tell me it's the new number that shows when I text. The phone and account show me my old number how is this . Thanks
View originalIf you’ve got an Android phone having “Chat features” turned ON can cause this problem.
If you’ve got an iPhone, perhaps Apple’s iMessage service hasn’t recognised your handset is using the number you wanted to keep, with your iD SIM card.
Hey
As
If it’s iPhone
Thanks mate it worked. Most helpful
Hey
As
If it’s iPhone
Most helpful Muhammed. Thanks
Hey
As
If it’s iPhone
Mohammed. Sorry. Predicted text
Hi i switched off the chat features my problem was solved. I still use WhatsApp. Messenger etc they work fine. Hope this helps
