wrong number on texts
  • 2 June 2023
  • 9 replies
  • 191 views
I received a new sim when switched networks.  I did the puk and kept my old number.  But people tell me it's the new number that shows when I text.  The phone and account show me my old number how is this . Thanks
Best answer by Mohammed 6 June 2023, 12:21
If you’ve got an Android phone having “Chat features” turned ON can cause this problem.
If you’ve got an iPhone, perhaps Apple’s iMessage service hasn’t recognised your handset is using the number you wanted to keep, with your iD SIM card.
Hey @Uriah herpo,
As @andewhite suggested, if it’s Android, turn OFF Chat Features.
If it’s iPhone
Thanks mate it worked.  Most helpful
Hey @Uriah herpo,
If it’s iPhone
Most helpful Muhammed. Thanks
Hey @Uriah herpo,
If it’s iPhone
Mohammed.  Sorry.  Predicted text
Hey @Uriah herpo,
Glad I was able to help!
I have the same issue on Android, can I fix it and keep the chat features?
Hi  i switched off the chat features  my problem was solved.  I still use WhatsApp. Messenger etc they work fine.  Hope this helps
Hi @Mady
I’d recommend switching off chat features and trying it again in a few days time to see if it has adjusted to the correct number.
