I have successfully ported in my old number to my ID mobile sim but recently it has stated to show my temporary ID mobile number when I send a text to anyone.
It is also an android phone.
Why is this?
Best answer by Rory
View originalI have successfully ported in my old number to my ID mobile sim but recently it has stated to show my temporary ID mobile number when I send a text to anyone.
Why is this?
Best answer by Rory
View originalIf you started using the Google Messages app (with chat features turned ON), after you joined iD with the number you didn’t want to keep, this might explain the issue.
The following online articles may assist you:
Anyway, hopefully this information helps - good luck.
Thank you, will see what happens.
Hi Rory, I'm experiencing the same issue but only a few numbers I text to show the temporary number all others seem to have my correct number.
Any idea how to resolve this?
So
it's an sansung A53
Try turning OFF the “Chat features” in the Messaging app - good luck
Thanks will see what I can find.
Okay
Anyway, hopefully these help.
It still had my temporary number showing and not my ported one.
I've tried to change it by verifying but it won't verify?
Hope this makes sense!
Okay
The user guide for your Samsung A53 will explain how to do this, or see the online video at https://www.youtube.com/watch?v=G3tIZGiEQBE
Otherwise it might be as follows:
