Hi. I traveling to turkey can some one tell me what are the charges of roaming there? Thanks
View originalHi. I traveling to turkey can some one tell me what are the charges of roaming there? Thanks
View originalHey there
Of course! Please click roaming at the top of the webpage below, and choose Turkey from the drop-down box to view the charges for calls, data and texts:
Any other questions, do let us know!
Kind regards,
I'm going turkey in two weeks can you add roaming to id
Nope, iD don’t sell any add-on packs for roaming,
You will be charged at the iD rates for Turkey, if you use your iD SIM card while visiting in Turkey.
Thanks for your reply
