roaming charges in turkey
Lucie Horakova
Hi. I traveling to turkey can some one tell me what are the charges of roaming there? Thanks
Mariasmum88 wrote:
I'm going turkey in two weeks can you add roaming to id
Nope, iD don’t sell any add-on packs for roaming, @Mariasmum88
You will be charged at the iD rates for Turkey, if you use your iD SIM card while visiting in Turkey.
  • 3502 replies
  • May 21, 2024
Hey there @Lucie Horakova, welcome to Community!
Of course! Please click roaming at the top of the webpage below, and choose Turkey from the drop-down box to view the charges for calls, data and texts:
Any other questions, do let us know!
Kind regards,
  • June 6, 2024
  • 12116 replies
  • June 6, 2024
  • June 6, 2024
Thanks for your reply
