Incoming calls not ringing - recipient is on another call
  • 20 January 2021
  • 205 views
Phone isn't ringing when people call me. They get a message saying I'm on another call (which I am not). Texts are coming through fine. I've had this issue in two different phones using the same SIM card.
Best answer by Mohammed 25 January 2021, 12:55
Yes, I'm having the same issue
Hello @Mdx  and @Lisa Haden,
If you’ve just joined us and ported a number, this could potentially be the reason if the port has not completed fully.
It’s odd indeed but we’d like to investigate this further.
I have sent you both PMs regarding this via the Community.
Please check your inbox here and we’ll try to help.
I have been with iD since August 2019 so not just joined.
This hasn’t been solved yet, not sure why it has been marked as solved. There’s another post on here with someone having the same issue five months ago. Hope you can sort it because I missing medical calls :(
Userlevel 4
Hi @Mdx
Do you have any sort of Call Forwarding/ Voicemail settings set within your phone itself?
We’ll send you a private message so that we can investigate this further though.
Simply click on your profile icon in the top right, then go to your private messages.
