issues with data since switching Xiaomi 11T Pro
I have  id mobile sim and I am experiencing the problem.
I don't receive any notifications from WhatsApp, messenger, bank or other apps whilst out and about using data. The phone goes mad when I return home and switch to WiFi
Never happened with other networks...
Best answer by WelshPaul 10 July 2023, 15:09
Sounds like your data isn’t working… What phone do you have @kadim?
Thanks for reply WelshPaul
I've got Xiaomi 11T PRO. I only started having that problem after I switched from 3 to ID mobile. When I test my network while on mobile data everything is ok
Hey @kadim,
Have you got a screenshot of the Access Point Name (APN settings) you can send us here?
Hey @Mohammed ,
Here's the screenshot
Thanks for reply @WelshPaul
So data does work and it’s just an issue with delayed or missing notifications while using mobile data? When using WiFI there are no issues?
Sounds like a DNS issue. Does your device have setting called Private DNS mode? If it does, turn it off.
@WelshPaul
It is only while using mobile data. I've just turned private DNS off. It was set to auto. Hopefully it will work
I had a similar issue using my Samsung S21 with SMARTY (Also uses Three network). For me, some internet based app notifications wouldn’t come through until I disabled this option.
I also set my DNS to 1.1.1.1 and no more issues for me.
Don’t forget to reboot the device after making such changes! 🤞
@WelshPaul
Seems to be working now 🤞. Thank you so much 👍🏻
Glad to hear @WelshPaul  was able to help answer this!
