Why would I not have an internet connection whenever my phone shows the 5g symbol? Once it goes back to 4g I can then connect OK. I thought iDMobile now supported 5g?
No internet connection when phone is connected to 5g
Hey
Yes iD Mobile does support 5G so this sounds like an unusual issue. Are you still experiencing problems?
I had the SIM card before 5g was available and only recently got a 5g capable phone. Is there anything I need to do to enable it, or should it just work?
