No internet connection when phone is connected to 5g
  • 24 July 2024
  • 40 views
Why would I not have an internet connection whenever my phone shows the 5g symbol?  Once it goes back to 4g I can then connect OK.  I thought iDMobile now supported 5g?
Hey @Waldy,
Yes iD Mobile does support 5G so this sounds like an unusual issue. Are you still experiencing problems?
I had the SIM card before 5g was available and only recently got a 5g capable phone.  Is there anything I need to do to enable it, or should it just work?
in theory @Waldy, it should just work. Perhaps try a NETWORK SETTINGS RESET on your new phone?
