Problem with texts
  • 23 December 2020
  • 6 replies
  • 102 views
I recently transferred my old number over to ID Mobile.
Whenever I send a text to someone they receive the same text three or more times and my phone says that the texts has failed.
Can this be fixed? It’s a bit annoying for the receiver and I can never tell if my texts have sent successfully or not if it’s saying that they’ve all failed.
Best answer by Mohammed 30 December 2020, 14:07
Hi @ella.henry,
Which phone do you have? After a port, we recommend resetting the network settings to ensure the phone has up-to-date network settings.
If you are using an iPhone, please try the below steps:
1)    Turn off iMessage (Settings > Messages)
2)    Restart your phone (by pressing and holding the on/off button)
3)    Tap Settings > Phone > My Number and confirm that it is correct.
4)    If it is not correct, please enter the correct number
5)    Turn iMessage back to On (Settings > Messages)
6)    Finally, go to Settings > Messages > Send & Receive and see if the correct number is displayed under “Start new conversations from:”.
Let us know if this helps and what phone make/model you’re using.
Thanks for getting back to me.
I have an iPhone 11.
I tried all the above steps and reset my network settings as recommended but unfortunately i’m still having the same problems
Hello @ella.henry,
This issue is caused by iMessage from my knowledge.
Should fix the issue but you’ve advised this has been tried.
When you go to Settings Messages and Send & Receive which number shows?
I tried the steps above for second time and network reset again but it still hasn’t worked.
On send & receive it has the correct mobile number.
Just to let you know I tried the steps for a third time and factory reset my phone and it has worked.
Thanks for your help
Badge +8
Oh great!
Cheers for letting us know @ella.henry.
Take care and have a lovely New year.
Will
