pac code not working correctly
  • 21 January 2023
  • 243 views
I began a new contract with ID just over a month ago.
I transferred my old number using PAC code which has worked however when I’m calling people the number that came with the new contract shows and I cannot receive any text messages to the number I have transferred.
I’ve tried in vain to talk to an advisor but have had no luck. This is a business phone and I’m losing customers!
Best answer by Lentil Northover 22 January 2023, 13:49
Live chat also doesn’t work- it’s just showing error codes
Hi @Lentil Northover,
Can you confirm which handset you are using?
Is the correct number being displayed in your settings under ‘My Number’?
Hey Kash,
I managed to speak to someone via Facebook.
apparently it’s a problem with iPhone handsets. She’s very kindly sent me out a new SIM card with the the attached to it to see if that works. I will keep you posted.
Hey @Lentil Northover,
Glad to hear she was able to help.
Sounds like it could also be due to a partial port but we can raise to the TechTeam to look into if the new SIM does not fix it.
