Do ID do a package for calls and data for people visiting the USA
View originalDo ID do a package for calls and data for people visiting the USA
View originalNope, iD Mobile don’t do a roaming package for the USA
When I visited the USA recently, I bought a cheap data only eSIM to use in the USA - it worked great.Â
FYI, the iD roaming charges for the USA are:Â
Â
Do you recall the details of the e-sim you purchased. ie. data quantity, company, price etc.
Did you purchase it before travelling or on arrival.
I think I used Soracom Mobile, because I travelled in both the USA and Australia, which were both covered by the package I chose.
Â
Thanks very much for your help I will have a look at this. Cheers.
Hey
I have seem some users use an eSIM and then forget to configure it correctly, thus incurred charges on their iD contract before it switched to the eSIM.
Â
You can't cap at £0 the leased you can do is £5.
If you have already used some of your cap you won’t be able to set it to £0.
You should be able to change it to £0 once you’ve paid the amount used.
Â
It definitely will not set to £0 I have tried it several times in the past even when I have used nothing of the cap.
Â
