On a £10 per month 60GB plan how much data can you use when roaming?
View originalOn a £10 per month 60GB plan how much data can you use when roaming?
View originalIf you mean you’ll be roaming in iD Mobile’s 50 inclusive roam like home destinations, then you are limited to 7.72GB a month under iD’s fair usage and open data policy.
You can work it out online at https://www.idmobile.co.uk/help-and-advice/eu-roaming/fair-usage-policy - scroll down to the “Open data policy” section of the page.
Good luck
