Majorca Roaming
  • 24 July 2023
  • 562 views
Is Majorca included with Spain for free roaming?
Best answer by andewhite 24 July 2023, 15:09
Yes @Des McLoughlin, you can use your iD plan’s calls, texts and mobile data allowances while roaming in Majorca.
Your plan’s inclusive EU roaming data allowance might be less than in the UK though - check online from the iD website at https://www.idmobile.co.uk/help-and-advice/eu-roaming/fair-usage-policy.
Hey @Des McLoughlin,
As confirmed above by @andewhite,
It’s included in roaming but do check your data as a fair usage policy applies and this depends on when you purchased to determine which of the two fair usage policies apply.
