Roaming calculations
  • 31 December 2022
  • 63 views
Hi, looking at taking out a new plan but to decide which one I need to understand how much roaming data is available. I have found a calculator into which you put the ‘plan cost’ and it gives you an amount of data but what is the plan cost - is it the monthly amount you sign up for or is that split down somewhere between device and plan (as both O2 and Virgin do)? it says you can see it on the app but as i don’t yet have a contract I dont have an app! thanks
Best answer by Mohammed 2 January 2023, 15:15
Hey @Sueshed,
We don’t split payments between the device and plan.
The monthly cost will be the line rental you pay per month.
Perfect, thanks
