I have a 120gb data plan. How much fair usage data will I have?
Okay
You can’t use all of your UK data allowance will roaming in the EU inclusive area, but the amount you can use depends on when you joined iD Mobile. The iD page about their “Fair usage & open data policies” explains it all.
If you’re roaming outside of the EU inclusive area, then you won’t have a roaming data allowance.
Thanks for the info. That link didn't seem to work for me though.
Links to the iD Mobile website www.idmobile.co.uk often don’t work if you’re signed-in to the iD Community.
Just sign-out of the iD Community before going to the main iD website
