I am going to Dubai next month and it’s not one of your roaming destinations. How do you suggest I make and receive calls while there? Should I buy a PAYG card while out there? Thanks
Best answer by Mohammed
View originalI am going to Dubai next month and it’s not one of your roaming destinations. How do you suggest I make and receive calls while there? Should I buy a PAYG card while out there? Thanks
View originaliD Mobile have roaming partners in Dubai (part of the United Arab Emirates), but it’s quite expensive.
Maybe use WhatsApp with Wi-Fi for calling and messaging while you’re in Dubai.
Hello
You mat best off getting a local SIM card when there as the rates are expensive and you’d hit your cap very quickly.
