APN settings Google Pixel 6 Pro
  • 13 September 2022
  • 199 views
I have followed the iD guide but it seems to have loads missing Server address/MCC etc, can someone please give me the full setting?
Ta
Best answer by WelshPaul 13 September 2022, 14:17
https://www.currys.co.uk/gbuk/techtalk/id-mobile-apn-settings/
nope still getting “Message not sent: service not activated on network” when sending a MMS.
The required device settings can be obtained by submitting your iD mobile number online at https://www.idmobile.co.uk/help-and-advice/get-your-settings/settings-tool.
Good luck @TheBeardedWelshman.
MMS Messages aren't included in your standard text allowances. These messages carry a charge of 30p per message. If you've got a spend cap applied on your account, you'll need to increase this to allow the extra charge. This can be done by logging into https://my.idmobile.co.uk/
You’ll need to increease your cap as mentioned above to send MMS messages.
