battery not lasting
  • 11 November 2022
  • 72 views
Since doing the latest update my battery isn't lasting more than 5 hours, without even using the phone  what can I do? Its a new S22, so disappointed.
Best answer by andewhite 11 November 2022, 14:17
Okay @Saffie Midgley, your Samsung should still be covered by the manufacturer's warranty.
I’d suggest using Samsung support, which is online at https://www.samsung.com/uk/support/contact/.
Hello @Saffie Midgley,
Samsung handsets as confirmed above, come with 24-months warranty so you can speak to Samsung or Currys to discuss a repair if the device is faulty.
