Since doing the latest update my battery isn't lasting more than 5 hours, without even using the phone what can I do? Its a new S22, so disappointed.
View originalSince doing the latest update my battery isn't lasting more than 5 hours, without even using the phone what can I do? Its a new S22, so disappointed.
View originalOkay
I’d suggest using Samsung support, which is online at https://www.samsung.com/uk/support/contact/.
Hello
Samsung handsets as confirmed above, come with 24-months warranty so you can speak to Samsung or Currys to discuss a repair if the device is faulty.
