I have been charged for using my data roaming in Corfu, I didn’t go over the limit.
Best answer by Macey1965
View originalI have been charged for using my data roaming in Corfu, I didn’t go over the limit.
View originalYou might have connected to a mobile network in Albania
Where you staying/visiting the NE end of Corfu?
Did you use your handset on a ferry while in Greece?
Roaming at sea sometimes uses the vessel’s satellite based mobile network, which is expensive and not included in your plan allowances.
Didn’t go on a ferry stayed in the north of the island in Sidari shocked it would pick up the mast in Albania however that may be the reason. I thought so myself, thanks for your reply.
Hey
Great idea I like it thanks a lot I will use it going forward.
Does the charge mark itself as something different on the bill?
If connected to a neighboring countries’ mast which is a chargeable area, this would charge, we’d recommend using manual network selection as opposed to automatic and setting the bill cap to a comfortable amount.
