corfu data roaming costs
  • 28 August 2023
  • 134 views
I have been charged for using my data roaming in Corfu, I didn’t go over the limit.
Best answer by Macey1965 29 August 2023, 16:23
You might have connected to a mobile network in Albania @Macey1965.
Where you staying/visiting the NE end of Corfu?
Did you use your handset on a ferry while in Greece?
Roaming at sea sometimes uses the vessel’s satellite based mobile network, which is expensive and not included in your plan allowances.
Didn’t go on a ferry stayed in the north of the island in Sidari shocked it would pick up the mast in Albania however that may be the reason. I thought so myself, thanks for your reply.
Hey @Macey1965, one way to avoid any out-of-plan use, while roaming, is set your iD account bill cap to £0.
Great idea I like it thanks a lot I will use it going forward.
Hi @Macey1965
Does the charge mark itself as something different on the bill?
If connected to a neighboring countries’ mast which is a chargeable area, this would charge, we’d recommend using manual network selection as opposed to automatic and setting the bill cap to a comfortable amount.
