data
  • 15 June 2022
  • 146 views
Hello.
If the roaming and international are on does this cover data abroad also?
Are you referring to these options in your iD MyAccount?
For more about International option, have a look at the “International Calling Guide” community article.
For the Roaming option, check out the “What is roaming and how does it work?” community article.
In summary:
  • International allows you to use your phone in the UK to call overseas numbers.
  • Roaming allows you to use your phone while you’re abroad/overseas.
Hello.
In addition, in order to use mobile data while you’re abroad, you’ll need to make sure this option is enabled on your handset.
Changing the settings for using mobile data while roaming varies from device to device, especially for Android handsets.
Away, good luck!
