Data Roaming Not Working in Germany
  • 13 April 2022
  • 106 views
I've arrived in Germany. I use a Pixel6. I've enabled data roaming on my phone. But, it's still not working. The iD guidance says to click on a link for APN settings (only "manual settings" address available, but doesn't tell you what to do with that info. I've never had a data roaming issue before. Any help gratefully received as I can't leave my hotel room without this (it's my map & translator)
Userlevel 2
Badge
Looks like the best network to connect to whilst roaming in Germany is o2
Hello @Debbie G,
The iD Mobile roaming partners in Germany are: O2 and Telekom.
Try turning off your phone for 10 minutes.
When you turn it on again, try manually selecting the network.
The “How do I ensure roaming is set up?” community article has got a “Check your APN settings” section, with details for manually changing APN settings.
On your Pixel 6 try looking for this under Settings > Network and Internet > Mobile Network.
Anyway good luck.
