Failed Basket check out > device data_info.browser_language is invalid or missing
I’m trying to check out a basket to buy a sim only.
I get to the last stage and then the page fails with error “device data_info.browser_language is invalid or missing”
Any advice?
And if the ID Mobile online shop code boffins are watching, you need to have a look under the bonnet of the last page at check out which is the page that asks for debit card details.
Cheers
SimJim
Best answer by SimJim 10 May 2023, 15:11
Sorted
The fail was using Chrome on Windows 11
Success with Firefox on Windows 11
Glad to hear you got it sorted.
I’ve marked your post as best-answer 😀
