I’m trying to check out a basket to buy a sim only.
I get to the last stage and then the page fails with error “device data_info.browser_language is invalid or missing”
Any advice?
And if the ID Mobile online shop code boffins are watching, you need to have a look under the bonnet of the last page at check out which is the page that asks for debit card details.
Cheers
SimJim
Best answer by SimJim
