I want to change my plan to SIM only. have a selection of plans offered through my account but it doesn’t specify anywhere how long the contracts are - can someone please advise?
Thanks!
How long are contracts for the plan changes I can see offered in my account?
If you are looking at plan changes rather than upgrades your contract term won’t change.
If your contract has already reached it’s minimum term your contract will keep rolling over and you can change the plan every 30 days.
Thanks Kash - so, to clarify, I’ve finished my contract and looking to change to SIM only plan as happy with my phone. The offers on my account i.e., £X for Ygb etc don’t say how long I get that price for/how long I’d be signing up for?
You should be able to discuss your change/upgrade options with the iD sales team
Call on 020 7139 1397, during normal office hours.
As for the SIM only plans on the upgrade section of the app, they should specify whether they’re a 12-month deal, a 24-month SIM only deal, or a 30-day rolling contract.
-Lauren
Hi, I spoke to the sales team already and agreed I could change my plan - as I’m out of contract - via my account, but nowhere (I’ve checked 3 times) does it say on the plans offered what term I’d be signing up to - annoying that info is not made available as I’ll have to ring the sales team again!
If it could be fed back to the higher echelons that the terms aren’t shown as it seems quite a big ommission…..
If you are upgrading to a SIM only contract it’s likely that it’s a 30 day rolling contract.
Please can you send us a screenshot so that we can check it out?
Hi Kash,
Screenshot below….
How does that work then? If they are rolling contracts does that mean that I can’t get a guaranteed price for longer? Or does it just roll over at the same price (until???)
Your help appreciated.
I believe the above screenshot is showing a plan change, not an upgrade per say.
Meaning the terms of your contract won’t actually change, just the allowances and price.
You wouldn’t be tied in for any longer.
So, mystery solved with a phonecall to Sales - posting here in case helps anyone else!
The page I was on - screenshot above - didn’t give contract lengths but turns out if you go to ‘All upgrade deals’ when you hit on upgrade (rather than ‘change plan’ - which is what I’m doing! - which takes you to the screenshot….) it takes you to all the sim only plans you can get, INCLUDING the contract length.
The website is just very badly designed…..
But we got there in the end :)
