Intermittant data signal
  • 16 June 2023
  • 45 views
Data keeps dropping out. Two days now. 4g showing  so phone signal fine. Internet drops out regularly. Is it the weather?
Best answer by Kash 18 June 2023, 16:43
Added:
If I take SIM out and put back in, I get signal for Internet. Lasts a few seconds  and disappears again
Hi @harpmandoodle,
Have you checked the coverage in your area using the link below?
Please also check the status checker in case there is ongoing work in the area.
Yes, and I'm borderline at home. I used to be well in, but it's shrunk. Moved further into property and I got 2 bars on data connection. Weird! I think it's the weather! Close this one and thanks.
Thanks for letting us know @harpmandoodle,
I can see Most Helpful has already been marked for this topic.
