Data keeps dropping out. Two days now. 4g showing so phone signal fine. Internet drops out regularly. Is it the weather?
Best answer by Kash
View originalData keeps dropping out. Two days now. 4g showing so phone signal fine. Internet drops out regularly. Is it the weather?
Best answer by Kash
View originalAdded:
If I take SIM out and put back in, I get signal for Internet. Lasts a few seconds and disappears again
Have you checked the coverage in your area using the link below?
Please also check the status checker in case there is ongoing work in the area.
Yes, and I'm borderline at home. I used to be well in, but it's shrunk. Moved further into property and I got 2 bars on data connection. Weird! I think it's the weather! Close this one and thanks.
