Issue logging into instagram
  • 25 April 2024
  • 8 replies
  • 49 views
Does anyone else have any issues accessing Instagram on data, when I open the app it gives me a "couldn't refresh feed" ? I'm able to access everything fine on WiFi and all other apps. I'm using Google pixel 8 pro
I've tried the following
- reinstalling app, also not on any beta versions
- logging out/in (sometimes this would work temporarily)
- restarting phone
Appreciate any help!
I'm having the exact same problem, tried all the above...using the Google 8 Pro just for reference with iD mobile.
Glad I’m not the only one, has this happened to you recently? For me, it started around a month ago.
I’ve also reported the issue to Instagram but not holding my breath out for a fix anytime soon
Userlevel 4
Badge
Hi @Frankieee, a quick question on this. Are you able to access Instagram via WIFI, and it’s data specifically that’s blocking access?
-Lauren
Hi @Lauren ,
Yeah I can access Instagram via WiFi but on data I can't
Yeah about a month ago too, it's been very annoying!!
Hi @Frankieee & @Rohdich
Okay, are you able to open Facebook and WhatsApp via data?
Hi @Tom
I’m able to open WhatsApp, Facebook, Facebook Messenger on data
@Frankieee,
It sounds like your issue is with Instagram as other apps are working fine.
Have you tried the SIM in another handset and checked if Instagram works on that handset?
If you are using an iPhone on Mobile/Cellular Data, you must allow internet access to the Instagram app in Settings.
