mobile data
  • 6 June 2023
  • 8 replies
  • 39 views
My phone says 4g but I have no internet
Hi @Graham Currie
I’m sorry to hear this, are you able to call or text?
What postcode are you having these issues?
Yes I'm able to call and text but no internet when it's saying 4g
Post code bt667gz never any problems with Vodafone
Hey @Graham Currie,
There’s no issues showing at this postcode from what I can see.
Have you ever been able to acccess data at this postcode?
Are you using an iPhone or Android?
I'm using android and never had any problems with Vodafone and data at address, thanks
Hi @Graham Currie
Have you tried resetting the network settings to see if this helps?
Vodafone is a different network and offer a different signal coverage, we at iD Mobile share with Three UK and their signal.
Yes reset it still the same 😐
Hi @Graham Currie
Are you able to try the SIM card in another device to see if the issue continues there?
