Hi I have no signal at all , this ridiculous every time I ring someone it goes off same if someone rings me , I've never had such bad signal until I joined id
NEARLY TWO HOURS ON HOLD TO YOUR COMPLAINTS DEPARTMENT
NO SERVICE
NO PORTING DONE
Â
ID MOBILE - WISH HAD NEVER JOINED THEM
I'm the same , is there a number you can tlring to complain , as I carnt see anyth8ng in the app , for any contacts , online eaither
The iD complaints department can be called on 0800 049 2402 or 0800 049 1300.
https://www.idmobile.co.uk/help-and-advice/complaints-procedure
Hey
Sorry to hear that.
Have you just joined iD Mobile or been with us for some time?
What’s the postcode of your area and have you tried restarting?
Â
Â
Hi ive been with you since febuary th8s yr and its been bad from the start yes ive turned off and on again al9t but no better postcode pr44rbÂ
Â
Okay, I’m not seeing any issues in the area, the coverage checker does show the area for a good 4G signal, 3G/5G may be weak here.
Â
All iD Mobile contracts have a time at the beginning to return based on being unhappy with the signal, as you mention you’ve had issues since joining us, was this explored when an option?
Â
H8 you are overoiusly not going to sort my issue , the signal is rubbish , when ppl ring me it goes off , im paying 25.99 and im not gettung any signal at all i have m9ved round the house and its no better , this is rediculous
Â
We’d like to help you fix your issue, however if the issue has been present since joining iD Mobile this may be the expected coverage in the area.
Â
We’ll shortly send you a Private Message to your Community account, so we can discuss your issue further.Â
Â
To access your messages, click your profile picture in the top right hand corner and then click ‘Private Messages’.Â
Â
Alternatively, if you are currently logged in, you can use the following link: https://community.idmobile.co.uk/inbox/overview Â
Â
We’ll see you there.Â
Â
