i had the text yesterday to say the switch to iD had happened and I’ve switched on and off several times but when I text it still says the original iD mobile number unless the text goes via WiFi
Have you tried a NETWORK RESET on your handset with the iD SIM card,
Doing so often fixes this issue.
Your handset user guide should explain the steps needed for a network reset.
Are you on an iPhone or Android?
I’d recommend the above from
For iPhone;
For Android;
Thanks for the responses
the network reset has not worked. I still cannot send text messages outside of WiFi
What error message is shown when you SMS using the mobile network,
Message send failure
when i go into messages the message has and exclamation mark with Not delivered in red underneath
Maybe your SIM card has been damaged, or is faulty,
Okay
It’s not possible to send an SMS from a mobile phone using Wi-Fi.
No
The Apple iMessage service is a proprietary system, for sending messages between Apple devices.
You can’t send iMessages to an Android handset.
I have text an android phone and seen it arrive but on my phone it says not delivered!
Thanks it has the iD mobile sim number not the one I ported from Vodafone but I can’t change it as it’s greyed out
Okay
