Number porting not fully worked
i had the text yesterday to say the switch to iD had happened and I’ve switched on and off several times but when I text it still says the original iD mobile number unless the text goes via WiFi
Have you tried a NETWORK RESET on your handset with the iD SIM card, @Joolzh13
Doing so often fixes this issue.
Your handset user guide should explain the steps needed for a network reset.
Hi @Joolzh13
Are you on an iPhone or Android?
I’d recommend the above from @andewhite to perform a network settings reset.
For iPhone;
For Android;
Thanks for the responses
the network reset has not worked.  I still cannot send text messages outside of WiFi
What error message is shown when you SMS using the mobile network, @Joolzh13?
@andewhite
Message send failure
when i go into messages the message has and exclamation mark with Not delivered in red underneath
Maybe your SIM card has been damaged, or is faulty, @Joolzh13 - perhaps it’s worth getting a replacement iD SIM card.
@andewhite  I am not technical but everything else is working so I why would the sim only be damaged for text messages?  the work on WiFi
Okay @Joolzh13, a malfunctioning SIM can cause strange behaviours, where some things work, and some don’t.
It’s not possible to send an SMS from a mobile phone using Wi-Fi.
  • What does “work on Wi-Fi” mean?
  • What make and model handset are you using?
@andewhite on iPhones texts can via WiFi
No @Joolzh13, the iPhone will send an Apple iMessage using Wi-Fi - mobile phones, including iPhones cannot send an SMS text message using Wi-Fi.
The Apple iMessage service is a proprietary system, for sending messages between Apple devices.
You can’t send iMessages to an Android handset.
@andewhite
I have text an android phone and seen it arrive but on my phone it says not delivered!
Have you checked the Settings > Phone > My Number option on your iPhone, @Joolzh13
@andewhite
Thanks it has the iD mobile sim number not the one I ported from Vodafone but I can’t change it as it’s greyed out
Okay @Joolzh13, if you’re not able to edit the value in the Settings > Phone > My Number option, and have already done a NETWORK RESET, you could try one more thing, ideally perhaps overnight.
  1. Turn OFF your iPhone.
  2. Remove the iD SIM card.
  3. Wait for at least 60-minutes.
  4. Insert the iD SIM card in your iPhone.
  5. Restart your iPhone.
Hi @Joolzh13,
We hope that you managed to get this resolved.
If you still require further assistance, please let us know.
