Signal keeps dropping despite saying it is in 4g. Also phone signal keeps showing an exclamation mark on pixel 6. This has happened at home for a while but currently in London where I would expect it to be perfect and it's worse than ever.
Hello
Does your iD SIM work well in a different handset?
Are you using the latest Android version with your Pixel 6?
Â
Not tried it in a different phone. I've always been on previous networks with other phones. On the latest version of Android.
Â
Okay
It’s definitely worth trying your iD SIM in a different device, and if possible try a SIM from another network provider your Pixel 6 (not three or SMARTY though).
That should give you a better idea of what’s going wrong - good luck.
Yes I joined ID when I got the pixel. I'll try the SIM in my old s9 and see how I get on. Thanks for your help
Â
Â
Â
