Unlimited Loyalty Addon Not On Allowance
  • 16 January 2023
  • 6 replies
  • 204 views
On my I'd mobile app I have an unlimited loyalty addon on my account but my allowance is still limited to 50gb, live chat customer service don't seem to.understand
Username: REMOVED
Can anyone help?
Dan
Best answer by Tom 17 January 2023, 15:59
Hi @Daniel Waller
Are you seeing the add-on in your app anywhere? When/where was the add-on applied?
Have you called 7777 to double check allowances too?
Hi Joe,
Yes it shows on the app but the allowance isn't showing it, see pic
I did ring 777 and it does say unlimited data but as you can see below there is a limit
What do you suggest
Dan
Hi @Daniel Waller
I can see the loyalty add on is mentioned there and will last until 29/11/23, so it looks like all is working as intended.
Hi @Daniel Waller
So when the data runs out I won't be charged ?, Before when I had unlimited it showed it on the dashboard
Hey @Daniel Waller,
Think it’s just how the plan was setup.
Once your data runs out, your loyalty add-on should kick in automatically so you won’t incur any charges.
Thanks guys 👍
