I'm not receiving incoming calls from NHS
  • 26 September 2023
  • 129 views
Hi I'm getting important calls from NHS but my phone isn't ringing, just vibrating once and there is no answer button to answer the callsĀ
Best answer by WelshPaul 26 September 2023, 15:13
Sounds like you may have added the number to your block list. What phone do you have?
I have a google pixel 6 proĀ
@Jean Meynell,
Can you check that the number isnā€™t blocked.
  1. Open your Phone appĀ .
  2. Tap MoreĀ More.
  3. TapĀ SettingsĀ and thenĀ Blocked numbers.
  4. Next to the number that you want to unblock, tap ClearĀ ClearĀ and thenĀ Unblock.
Sorry but it's not a blocked number but thank you anywayĀ
Hi @Jean Meynell,
Is the software up to date? Do you get issues with any other numbers?
It may be worth testing it in another handset as it may be a handset issue.
Ā
My phone did a software update at the beginning of the week and unfortunately I don't have another handset I can try my sim inĀ
Hi @Jean MeynellĀ
Ā
Have you been able to accept calls from the number before while on iD Mobile or never?
Ā
