Hi i can not use my phone in Spain and I have all roaming switched on
Have you checked that your APN settings are correct?
If so, what network are you connecting to?
The iD Mobile roaming partners in Spain are: Yoigo and Movistar - according to the iD Community online FAQ “Where can I use inclusive roaming?”.
Did it ever work? You haven’t used your roaming allowance up?
Was roaming enabled on the iD Mobile account and on your phone?
It may be worth testing both the network partners that
Hey
Is it all services or just data impacted here?
If it’s just data then make sure Data Roaming is on.
If it is, then the issue lies with your APN settins being incorrect.
Hey
That’s odd indeed as It’s the first I’ve heard of this type of issue.
Usually it’s calls only (because of incorrect dialling code 0 instead of +44 not being used).
Or Data (DATA Roaming not enabled or incorrect APNs).
What number are you texting, is it a UK Mobile number or an international one?
