I’ve just learnt that I will only be able to use 21.60 GB when roaming in a Band 1 country (as opposed to my 100GB plan) free of charge. I will be charged for anything above 21.60GB. I am only going for a week, but may use a lot of data.
I think ID is misleading customers by saying you can “roam like at home”. You can’t.
I only learnt about this by reading the small print on the roaming page. I think ID should put this on the “Remaining Monthly Allowances” dashboard, to make it clear.
ID, will you do this? It’s misleading if you don’t.
Best answer by Mohammed
