Issue logging into instagram
Does anyone else have any issues accessing Instagram on data, when I open the app it gives me a "couldn't refresh feed" ? I'm able to access everything fine on WiFi and all other apps. I'm using Google pixel 8 pro
I've tried the following
- reinstalling app, also not on any beta versions
- logging out/in (sometimes this would work temporarily)
- restarting phone
Appreciate any help!
I'm having the exact same problem, tried all the above...using the Google 8 Pro just for reference with iD mobile.
Glad I’m not the only one, has this happened to you recently? For me, it started around a month ago.
I’ve also reported the issue to Instagram but not holding my breath out for a fix anytime soon
Userlevel 4
Badge
Hi @Frankieee, a quick question on this. Are you able to access Instagram via WIFI, and it’s data specifically that’s blocking access?
-Lauren
Hi @Lauren ,
Yeah I can access Instagram via WiFi but on data I can't
Yeah about a month ago too, it's been very annoying!!
Hi @Frankieee & @Rohdich
Okay, are you able to open Facebook and WhatsApp via data?
Hi @Tom
I’m able to open WhatsApp, Facebook, Facebook Messenger on data
@Frankieee,
It sounds like your issue is with Instagram as other apps are working fine.
Have you tried the SIM in another handset and checked if Instagram works on that handset?
If you are using an iPhone on Mobile/Cellular Data, you must allow internet access to the Instagram app in Settings.
@Kash I’ve tried the sim card in another device (Pixel 4 XL) and that doesn’t seem to have any issues
I'm having this exact same problem on my pixel 8. I've followed advice to fix it and it's not worked. I've raised a complaint with the network and.still it's not working. Maybe it's a pixel issue?
Hi @Frankieee & @Finmoo
Every here having issues appears to be on a Pixel device, has a network settings reset been tried?
@Tom I’ve given that a try and still no luck
Okay @Frankieee, your Instagram app works on a Pixel 4 XL, but not a Pixel 8 Pro?
Are these devices using the same version of Android?
Perhaps dark arts by Google, directed against META?
@andewhite Hahaha maybe. They are not using the same versions, Pixel 4xl is on the latest possible (Android 13) and Pixel 8 Pro is on Android 14.
It’s strange that they were working a few months ago
Hi @Frankieee
We’d recommend contacting Google or Meta for further support.
