my phone number is shown as unknow to others
  • 26 July 2024
  • 8 replies
  • 28 views
when i call someone its not showing my number to them. They are see it as unknow number when i make calls to someone. Can you please let me know what settings i have to update so that my true caller number is displayed to others when i make calls ?
You should be able to change the mobile number on your set in the settings of the dialler / phone app, @prakashpanchadi.
Perhaps your handset hasn’t detected the mobile number from the service provider?
Hi @prakashpanchadi
Have you tried the above from @andewhite?
Yes i tried it. But it didn’t worked.
Userlevel 5
Hey there @prakashpanchadi, what phone do you have please?
Motorola 40 Razr
Hi @prakashpanchadi
Okay, the option to hide a number is an in device setting, it would be a setting on our side.
Have you tried your SIM card in another device to see if the same happens there?
I am using a different service provider sim in new ID contract phone ( Motorola 40 Razr ) . That is causing the problem. I am not able to receive caller ID on the Motorola 40 Razr.
I haven’t put my ID number into the Motorola 40 Razr.
My ID number is still on my Old samsung phone which is working fine.
Userlevel 5
Hey there @prakashpanchadi, so to confirm, do you have the iD Mobile SIM card in your phone?
