my phone number is shown as unknow to others
when i call someone its not showing my number to them. They are see it as unknow number when i make calls to someone. Can you please let me know what settings i have to update so that my true caller number is displayed to others when i make calls ?
You should be able to change the mobile number on your set in the settings of the dialler / phone app, @prakashpanchadi.
Perhaps your handset hasn’t detected the mobile number from the service provider?
  • 12416 replies
  • July 26, 2024
  • 8408 replies
  • August 5, 2024
Hi @prakashpanchadi
Have you tried the above from @andewhite?
  • 10 replies
  • August 6, 2024
Yes i tried it. But it didn’t worked.
  • 4543 replies
  • August 12, 2024
Hey there @prakashpanchadi, what phone do you have please?
  • 10 replies
  • August 12, 2024
Motorola 40 Razr
  • 8408 replies
  • August 19, 2024
Hi @prakashpanchadi
Okay, the option to hide a number is an in device setting, it would be a setting on our side.
Have you tried your SIM card in another device to see if the same happens there?
  • 10 replies
  • August 19, 2024
I am using a different service provider sim in new ID contract phone ( Motorola 40 Razr ) . That is causing the problem. I am not able to receive caller ID on the Motorola 40 Razr.
I haven’t put my ID number into the Motorola 40 Razr.
My ID number is still on my Old samsung phone which is working fine.
  • 4543 replies
  • August 26, 2024
Hey there @prakashpanchadi, so to confirm, do you have the iD Mobile SIM card in your phone?
  • 10 replies
  • September 23, 2024
Yes, I have the ID Sim. WHn i sue the ID sim in the phone its is working fine. But when i put someother network provider sim in the phone then i am not getting the caller number displayed if someone call me.
  • 8408 replies
  • September 26, 2024
Hi @prakashpanchadi
Okay, you may need to ask the network provider whose SIM card isn’t working.
  • 10 replies
Ok, But can you confirm if the Phone is not locked with the network ?
  • 8408 replies
  • October 1, 2024
Hi @prakashpanchadi
If you bought it from us, it isn’t locked to our network.
  • 10 replies
  • October 1, 2024
I have taken the phone on mew contract from Carphonewarehouse which is part of Currys.
The network provider is ID.
  • 8408 replies
  • October 4, 2024
Hi @prakashpanchadi
It won’t be locked from Currys/Carphone either.
