when i call someone its not showing my number to them. They are see it as unknow number when i make calls to someone. Can you please let me know what settings i have to update so that my true caller number is displayed to others when i make calls ?
my phone number is shown as unknow to others
You should be able to change the mobile number on your set in the settings of the dialler / phone app,
Perhaps your handset hasn’t detected the mobile number from the service provider?
Yes i tried it. But it didn’t worked.
Motorola 40 Razr
Okay, the option to hide a number is an in device setting, it would be a setting on our side.
Have you tried your SIM card in another device to see if the same happens there?
I am using a different service provider sim in new ID contract phone ( Motorola 40 Razr ) . That is causing the problem. I am not able to receive caller ID on the Motorola 40 Razr.
I haven’t put my ID number into the Motorola 40 Razr.
My ID number is still on my Old samsung phone which is working fine.
