poor reception and no data connection
  • 5 December 2023
  • 10 replies
  • 84 views
Really bad signal and very poor reception from my phone, signal only shows 1 bar. Reset phone and still the same? Any help please
Is the issue in one location, or everywhere you’ve been trying to use your iD SIM @Melevo100?
It's where ever I go .
Do you get the same behaviour when using the iD SIM card in a different handset?
If yes, you could have a damaged / faulty SIM card @Melevo100.
Is your handset approved for use on the iD network?
Hi @Melevo100
What device are you using the iD Mobile SIM card with these issues?
Have you tried a different device?
Please could you let us know the postcode(s) where you’ve had these issues?
Dh4. Ts1 dh1 . Its mainly Internet connection I lose. I'm currently sat at dl1 postcode and no Internet connection
It's a Samsung s23. New device as of 3 weeks ago
Well after nearly an hour on the chat I've been told it's a sim issue, it's only 3 weeks old. Let's see when new one arrives?!?!?
Hi @Melevo100
Please could you provide the full postcode(s) so we can take a look.
Hopefully a new SIM card is the fix here.
I don't have another device and it's dh46ae
Hi @Melevo100,
We can’t see any issues in the area or any work being carried out in your area.
If you are able to test the SIM or alternatively you can collect a replacement SIM from your local Curry’s store to test.
