Since shortening the ring from 30 to 20sec, voice mail not working - says number not recognised. Have tried all the suggestions on site and have been to Carphone warehouse they cant help, any suggestions.
Best answer by fauvehound
View originalSince shortening the ring from 30 to 20sec, voice mail not working - says number not recognised. Have tried all the suggestions on site and have been to Carphone warehouse they cant help, any suggestions.
View originalHi
Did you respond to the message sent on here?
If not, please click on your profile icon in the top right, then go to your private messages.
I have now been told after one week with the IDmobile tech team?? that Iphone11 cannot change the Voicemail rings and is defaulted to 30 😡
What a waste of time and energy back and forth for two weeks!
Should have stuck with giffgaff….a bad decision to move 👎
The problem states it is SOLVED!!
It has not for this particular handset 😡
**61*447782333123**20#
(You may need to repeat a few times until you get a “success” message on the iPhone.)
Just keeps saying failed!
I know this is an old thread, but just in case someone comes across it in future, the following (as posted above) worked for me:
This gives my number a 20 second delay before going straight to VM. Before the change, my phone would ring for 30 seconds & stop, but then the caller would continue to hear ringing for another 30 seconds before it finally went to VM.
