voicemail no longer working after shortening ring time
Since shortening the ring from 30 to 20sec,  voice mail not working - says number not recognised. Have tried all the suggestions on site and have been to Carphone warehouse they cant help, any suggestions.
Best answer by fauvehound 26 August 2020, 14:17
Userlevel 4
Hi @MCR
Did you respond to the message sent on here?
If not, please click on your profile icon in the top right, then go to your private messages.
I have now been told after one week with the IDmobile tech team??  that Iphone11 cannot change the Voicemail rings and is defaulted to 30 😡
What a waste of time and energy back and forth for two weeks!
Should have stuck with giffgaff….a bad decision to move 👎
The problem states it is SOLVED!!
It has not for this particular handset 😡
@MCR what happens if you dial:
**61*447782333123**20#
(You may need to repeat a few times until you get a “success” message on the iPhone.)
Just keeps saying failed!
I know this is an old thread, but just in case someone comes across it in future, the following (as posted above)  worked for me:
This gives my number a 20 second delay before going straight to VM. Before the change, my phone would ring for 30 seconds & stop,  but then the caller would continue to hear ringing for another 30 seconds before it finally went to VM.
